Hello my name is chad and I have an 1995 ford escort 1.9l LX with 108,000 miles. Last week Aug 1st I was at work and my car would not start. When I turned the key over I had power and everything but no noise when I turned the key to start. As soon as I hooked up jumper cables my car fired right up and was running fine. Today Aug.8 I went out to start my car and it did the same thing again. I hooked up jumper cables again and nothing this time. I had my battery tested and it passed. I changed my ignition relay and still nothing. I have no idea if it could be my starter or alternator. I was told it cannot be the alternator. But if my starter was shot wouldn't it make a ticking noise when i hold to key over to start? I am just stuck on this and i would appreciate it if you could help me..
thank you
chad
thank you
chad
Aug 8, 2007 at 3:51 PM
