Speed sensor
SLIMJIM40
  • FORD ESCORT
I have a 1999 ford escort zx2
it has129000 thousand miles on it.
the engine size is a 2.1
i have a service engine light that keeps coming on and the engine jerks when I take off
i have had the speed sensor replaced twice and I still have the same problem the mechanic cant find the problem he said it maybe the transmision help.
Sunday, July 8th, 2007 AT 11:47 AM
JWALTH02
  • 180 POSTS
Did you have that mechanic pull the codes for you? If not go to an autozone or checkers if available and have them pull them for free. Then let us know what they are.
Sunday, July 8th, 2007 AT 1:16 PM
SLIMJIM40
Yes they did a check and the code number was po715
Sunday, July 8th, 2007 AT 4:58 PM
MERLIN2021
  • 17,250 POSTS
P0715 Turbine Shaft Speed Sensor Circuit
Might check wiring as well.
Sunday, July 8th, 2007 AT 5:18 PM
