Engine Performance problem
1999 Ford Escort 4 cyl Front Wheel Drive Automatic 180K miles
Hello
My Escort was running very rough. Infact it would cut off at times when I stopped at a light etc. I swapped plugs with cyl 2 (Error code PO302), Lots of spark. I unplugged the injector, which made no difference in the way it idled. I put on new wires.
Through the process of elimination, I figured it would have to be a bad injector. Took the injector out and replaced it with a new one. It made no difference at all.
I thought the coil might be faulty, but I'm getting lots of spark on that cylinder.
Any suggestions.... I am financially challenged so inexpensive suggestions work best for me to begin with.
Thank you
Terry
Hello
Thank you
Terry
Sep 22, 2010 at 4:44 AM
