1999 Ford Escort Exhaust Noise
JFOY1984
Hi my name is Justin and I am new to this site. I have a 1999 Ford Escort SE with approx 86,000 miles. I am having a problem with a loud noise coming from the exhaust. I am unable to call around to get prices to get it fixed because I havent a clue what the name of the part of the exhaust is. It is located about 1-2 feet from the manifold and has a flexible braided texture and is about a foot long. I know it is not the converter. Anyone have a clue what this part is called?
Feb 23, 2006 at 7:31 PM
LOVESCARS
  • 359 POSTS
Front flex pipe! Yes that's it. You can pruchase universal aftemarket pipes the original equipment ones can be pretty pricey.
Exhaust work is a pisser unless you have the correct tools or the exact fit.
Feb 24, 2006 at 12:46 PM
SNIKREPN
  • 17 POSTS
Noise never matters much. However, if it sounds like there is some knocking of components then it can be a serious one and should be checked before anything bad emerges. You also need to know that exhausts behave funnily with some engines so you should find out if at all they are compatible.
Mar 8, 2013 at 4:24 AM
Suggested Repair
The flexible braided section about 1-2 feet from the manifold is the front flex pipe. Universal aftermarket flex pipes are available and usually cost less than original equipment; exhaust work is easier with the correct tools or an exact-fit part.
Conversation Summary
A 1999 Ford Escort SE owner with about 86,000 miles reported a loud exhaust noise and asked what the flexible braided section roughly 1-2 feet from the manifold is called, noting it is not the catalytic converter. An expert identified it as the front flex pipe and said universal aftermarket pipes can be purchased because original equipment parts are expensive, adding that exhaust work is difficult without the right tools or an exact fit.
