no hot air just constant cold
ARCTICJOHN1
i have a 1999 ford escort van 1800 (diesal) 106,000 mils. i have no hot air blowing in the van butt the fan is working, i have changed the stat but stil only cold air what else could it be?
Nov 15, 2007 at 7:12 AM
SELTOR
  • 9 POSTS
I was having trouble with my heater blowing warm air when the car, itself, was actually getting gas to it. It turned out to be low water/coolant in the radiator. I would suggest simply adding more water/coolant to your radiator (I used 50/50 mixture). If this doesn't solve your problem, then I can't help you anymore!
Nov 20, 2007 at 12:54 PM
