M reg Ford Escort
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Identify the exact engine and fuel system before following an idle-control procedure. Have the stalling diagnosed rather than treating the suggestions as confirmed failures.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis.
Patrick
Discussion summary
M reg Ford Escort
After a holiday, an M-registration Ford Escort would run only while the owner maintained engine speed and stalled at idle. Replies suggested idle-air-control or throttle-position faults. The owner planned to obtain a manual and possibly take the car to a shop.
Reported outcome: No inspection findings or repair result were reported.
A throttle-position repair on another owner's Taurus does not identify this Escort's fault. Proposed tapping, cleaning and lubrication are not a verified procedure for it.
