1996 ford escort, 1.9 ci., 200,000 km., new rad cap and thermostat, .... when I filled the rad with coolant and started the engine it blew the coolant out off the Rad.... I than filled the rad again with the engine off, top rad, hose hot... the in heater hose Hot.. the out heater hose cold.. I drove the car for 5 miles and let idle for 10 minutes,.... dash gauge shows normal, still cold air out off the heater. could it be a head gasket ? or water pump ? or plugged radiator/heater core?
Dec 7, 2007 at 11:02 AM
