heater blower
MDENNIS7168
2000 Ford Escort. Heater blower stopped working - stopped to go to ATM, came back & did not work. tested circuit breaker for continuity -OK. Swiched circuit breaker with same size one for power windows - no effect (do not have power windows). pulled blower & tested with battery - OK. removed switch -inspected - looks OK. Is there a relay somewhere that the ignition switch enables to send power to the circuit? That is the only thing I have not been able to find / trace. :roll:
Aug 6, 2007 at 1:26 PM
  • 75,988 POSTS
You are probably looking for the resistor pack-let me know if you cannot find it and i'll go look for it for the mean time
https://images.2carpros.com/forum/automotive_pictures/12900_baby_smoking_3.gif
I'll be taking a break see you later
Aug 6, 2007 at 8:52 PM
  • 75,988 POSTS
I've finished my puffing-I believe that the resistor pack is behind right side of the dash in the AC-Heater plenum.
https://images.2carpros.com/forum/automotive_pictures/12900_baby_smoking_4.gif
I'll be on break again
Aug 6, 2007 at 9:00 PM
MDENNIS7168
I did pull the resistor pack & checked continuity across that as well & found no issues there either. So I am still stumped.
Thanks for your prompt reply.
Aug 7, 2007 at 11:40 AM
