1986 Ford Escort Headlights Stuck On Fix
LADYJANE
My kid jammed his knee into the on off switch on his 86 ford escort and I can't turn them off. I had to remove the pos on the battery to get them to turn off. (Late at night and just didn't have the light or time to find the fuse). How do I get to the switch to replace it? I would like to take the dash out to repair it since it has a large crack in it and thought it might make getting to the switch easier but do not know where to start? This is a 1986 Ford Escort L. Any ideas?
Sep 29, 2007 at 1:39 AM
MERLIN2021
  • 17,250 POSTS
First, do not use the positve cable to kill the electrical! Pull negative now then reconnect pos.
If you reach under the dash for the switch in the back you will feel a button, press it or pull it and you can pull the nob and shaft out of the switch, then undo the connector, then unscrew the nut on the dash!
Sep 29, 2007 at 1:51 AM
Suggested Repair
Reconnect the positive battery cable and disconnect the negative instead. Reach under the dash, press or pull the release button, pull out the knob and shaft, unplug the connector, and unscrew the retaining nut to remove the headlight switch.
Conversation Summary
The owner of a 1986 Ford Escort L said a jammed headlight switch left the headlights stuck on, and disconnecting the positive battery cable was used to shut them off. They asked how to access the switch, possibly while removing the cracked dash. The expert advised using the negative cable instead and explained how to release and remove the switch from under the dash.
