1986 Ford Escort Fuel Pressure Specs
TCU27
86 escort 1.9 lx what is the fuel pressure supposed to be . also what is the compression supposed to be?
Jul 25, 2007 at 8:26 AM
  • 75,988 POSTS
[quote:430139ea52="tcu27"]86 escort 1.9 lx what is the fuel pressure supposed to be . also what is the compression supposed to be?[/quote:430139ea52]
Feedback Carb: 4.5-6.5psi
EFI: 35-42psi
Jul 26, 2007 at 11:03 AM
Suggested Repair
Compare fuel pressure to 4.5-6.5 psi if the engine is carbureted, or 35-42 psi if it is fuel injected. The replies did not give a compression specification.
Conversation Summary
The owner of a 1986 Ford Escort 1.9 LX asked for the specified fuel pressure and compression. The expert said carbureted systems should read 4.5-6.5 psi and EFI systems 35-42 psi, but did not answer the compression question or identify which fuel system applies.
