1991 Ford Escort Fuel Leak Under Tank
CHUCKOYA
1991 ford escort 1.9L 250,000km hi when i start my car it drips gas under the gas tank. The car runs fine but leaks gas it does not stall. my question is does this sound like the return line is damaged?
and will it be a costly repar to have a mechanic put a new line or lines in
Oct 4, 2007 at 12:01 PM
  • 31,937 POSTS
Hi there,
You will have to get the car on a hoist and have a good look around, it may just be a gasket at the fuel sender or a rubber hose, but regardless with the price of fuel these days you will only be saving money getting it fixed.
Mark (mhpautos)
Oct 4, 2007 at 12:36 PM
Suggested Repair
Raise the car on a hoist and inspect the tank area. The leak may be a fuel-sender gasket or rubber hose rather than a damaged return line; repair the leaking part promptly.
Conversation Summary
The owner of a 1991 Ford Escort 1.9L reports gasoline dripping under the tank after startup, although the car runs normally. They ask whether the return line is damaged and how costly a line replacement would be. The expert recommends a hoist inspection, noting it may instead be a fuel-sender gasket or rubber hose, and advises repairing the leak.
