:roll:
Ford Escort Fuel Filter Leak
:roll:
Update: While messing with it yesterday i noticing the fuel filter was loose on it bracket so I shook it up and down to simulate the rough roads here in town and what do you know the bottom line popped off!
I pushed it back upon the filter with the plastic catch pin pulled out and then pushed the push pin back in place tightened down the fuel filter bracket and tested to see if the bottom line would pull loose.
It's not leaking for now but stay tuned to see if our moon craters (I mean chug holes) shake it loose again
Ford why can't you guys put maintenance things where people can get at them?? :evil:
Suggested Repair
Secure the fuel filter firmly in its bracket and fully seat the bottom fuel line, then lock the plastic retaining clip. Confirm the line cannot be pulled off. If the leak returns, inspect or replace the line O-rings and have the connection rechecked.
Conversation Summary
The owner of a Ford Escort reported intermittent gasoline dripping from the bottom of the fuel filter, mainly after slow driving, starting after a recent filter replacement. The shop found it dry and suggested water. An expert advised reproducing the leak and checking the filter connections and O-rings. The owner later found the filter loose in its bracket; shaking it made the bottom line pop off. Reseating the line, locking the plastic clip, and tightening the bracket stopped the leak for the time being.
