1999 Ford Escort Fuel Emissions Not Ready
Suggested Repair
Replace the gas cap and confirm it is tight. Have the evaporative emissions system checked for leaks in the lines, canister valve, or tank vent valve, using a smoke test or light air pressure with soapy water. Obtain the actual diagnostic code; the fuel-emissions monitor will not become ready until the underlying fault is repaired. Codes are cleared with an OBD2 scanner, not by removing a chip.
Conversation Summary
The owner of a 1999 Ford Escort said a fuel-line repair was followed by a claim that a chip had been removed and the computer memory erased. Three months later, the fuel-emissions monitor still read not ready for a smog test. Experts said that explanation was incorrect and that an evaporative emissions leak, often a loose or defective gas cap, leaking lines, a stuck canister valve, or a bad tank vent valve, can prevent the monitor from setting until the fault is fixed. They recommended getting the specific code and leak-testing the system.
