Front passenger door problem, 94 Ford Escort
1994 FORD ESCORT
AMI
I recently got a 94 Ford Escort. The front passenger side door opens fine from the outside but will not open from the inside. This is very annoying to my passengers, as they cannot get out without rolling down the window and using the outer door handle! I keep wondering if there is some kind of childproof setting on the door, or if the inside door handle is broken. This is a manual lock, not automatic. Thanks for any advise you can give!
Jan 15, 2006 at 10:36 AM
DUDE
  • 50 POSTS
sounds like rod between handle & lock has come off ,would require taking off door panel to check & or correct
Jan 16, 2006 at 5:54 AM
AMI
Thanks, I was hoping for a button to push, but oh well! I have a Chiltons that came w/ the car, will remove door panel and inspect.
Jan 17, 2006 at 3:02 AM
