1996 Ford Escort Electrical Buzz
SOOLKYUT
My 96 Escort has developed a buzzing sound that is definitely electrical. It used to be intermitent but now occurs at all times when the engine is on. It seems to be coming from the passenger side air bag. The strange thing is my high beams have stopped working (turn on high beams and the lights die) but my low beams are ok. Noise stops when I turn on lights, or engage parking brake. It also changes pitch when any of the other dashboard lights are light (i.e. turn signal or hazards or rear defrost). Any ideas
Nov 16, 2006 at 6:18 AM
BRUCE HUNT
  • 3,754 POSTS
Sounds like a failing relay. Possibly related to the lights. Check for relays under the hood and the fuse box in the car. There is probably a fuse box under the hood that has additional relays.
Nov 16, 2006 at 12:23 PM
Suggested Repair
Inspect relays under the hood and in the interior fuse box. A failing relay, possibly related to the lighting circuit, may be causing the electrical buzz and high-beam failure.
Conversation Summary
The owner of a 1996 Ford Escort reports a constant electrical buzzing near the passenger air bag, high beams that fail when selected, and a noise that stops or changes pitch with the lights, parking brake, or dashboard indicators. The expert suggests a failing relay and recommends checking relays in the underhood and interior fuse boxes.
