vibration at speed after curbing my wheels
1998 FORD ESCORT
VISUALJAZZ
I recently hydroplaned into a curb and ruined the lower control arm. I replaced it. My tire vibrates a little when driving. I took a picture of the tire area. I think that the axle might have been damaged.
Car runs fine no transmission problems just unstable tire, need tires realigned, probably new axle?
What do i need to do? Thanks.
Oct 27, 2006 at 2:52 AM
RAGS729
  • 29 POSTS
At the least the boot needs to be replaced, if there is doubt you may as well replace the shaft and not take a chance. Are you sure you didnt bend a wheel?
Oct 27, 2006 at 8:13 AM
VISUALJAZZ
What do you mean by a wheel? The rim was replaced.
Oct 27, 2006 at 1:33 PM
RAGS729
  • 29 POSTS
By wheel I meant rim but if the wheel has been replaced then the shaft could very well be bent. Try raising the car up and rotating the tire and see if you can look at the shaft to see if it is bent.
Oct 27, 2006 at 7:20 PM
