Escort half shaft replacement issue
FORD ESCORT
DEBORD
I have a 97 ford escort w/ 5 seed; no ABS. I am not able to get the half shaft from the transmission. Everyone tells me that it should pry out easily. I spent an hour with a prybar and it would not budge.
Am I missing someting or is there a trick that I could try?
I appriciate any advise!
Barry
Jun 28, 2007 at 9:12 PM
CRAIGFL
  • 89 POSTS
Here's the trick-- I've done four so far. I started with the pry bar like you and could NEVER get them out. What you need is two tapered pieces of metal-- two large, flat, screwdrivers will work. Get under there and put one between each side of the driveshaft and the transmission case-tap them into place with a hammer. Now start tapping on the end of each screwdriver and eventually it will go "pop" and come out--- it's held by a steel ring on the end of the shaft.
Remember, one at a time or the ring gear will fall loose inside the housing!
Jun 29, 2007 at 6:50 AM
