Hi, got a 1997 1.6 Escort RHD, THE BRAKE PEDAL IS TOO LOW , so the brake light switch is on all the time. It needt to be about2-3cm higher, the lingage the the servo and master cylinder look ok, there is no adjustment on the footbrake end, is it possible the pedal or cage is bent?! :?
Aug 22, 2007 at 4:44 AM
