Engine Oil Dipstick Tubing
FORD ESCORT
MNJMOYER
The engine oil dipstick tubing has come off of the engine block where it connects & no other parts are found except the upper tubing itself, how do I repair this? Is there a cheap way to fix it?
Sep 2, 2007 at 10:53 AM
DSPLC
  • 220 POSTS
The oil dipstick tubing is only one piece, there is no other parts.. I saw a ford engine being rebuilt before, the mechanic put a grease at the bottom part of the tube and he just push the tube little by little inside the hole of the engine block. He was holding the tube more on the bottom part. Then, he bolted the bracket on the top of the tube so it would not move.
Unless you broke the bottom part and left some part of the tube inside the hole of the engine block. Now, that is hard to fix.
Sep 3, 2007 at 9:36 AM
