I have a 1996 Ford Escort, 1.9l engine. NO A/C. Once the car is started the cooling fan comes on and stays on constantly until the engine is shut off. It does not come on when the key is turned on, only after the car is started. The engine is not overheating and runs within specs. The fan that is running constant, is the high side fan. I have quickly checked the relays and wiring (for corrosion) and can't find anything wrong at this time. I have noticed other Fords do the same thing. Could I have a faulty relay or is there something wrong with the ground system going through the computer?
May 8, 2007 at 1:04 AM
