95 ford escort............
it starts up, then runs for a good 4 minutes, then stalls, i got two codes from my scanner which are 172 and 538:
:arrow: :?: [b:654b973af2]172: lack of heated oxygen sensor (h20s-1) switches, indicates lean bank #1[/b:654b973af2]
[b:654b973af2]538: which is insufficient rpm change[/b:654b973af2],
what in the hell is 172 saying? :x
here are the things i have done:
1)changed the air filter
2)changed the fuel filter
3)changed the fuel pump
4)changed the o2 sensor
5)changed out with a used MAS
6)changed out with a used IAC (both from pick n pull)
8)new gaskets in all the necesary parts
