Blown Fuel Injector Fuse
LINDA1975
I have a 1999 Ford Escort the mileage is 219000, it keeps blowing the fuel injector fuse, I was told it could possibly be caused by the fuel pump we changed the fuel pump it is still blowing the fuel injector fuse could you tell me what else might be the problem.....
Aug 21, 2006 at 8:25 AM
MIKEYBDMAN
  • 623 POSTS
[quote:cb98ca9f96="Linda1975"]I have a 1999 Ford Escort the mileage is 219000, it keeps blowing the fuel injector fuse, I was told it could possibly be caused by the fuel pump we changed the fuel pump it is still blowing the fuel injector fuse could you tell me what else might be the problem.....[/quote:cb98ca9f96]
To start with, the chances of a fuel pump blowing that breaker are slim and none. I hate that someone cost you that money for nothing.
Here is what that fuse powers. You will have to find out what is drawing too much current and blowing the fuse, or is shorted.
Power flows thru the CCRM and supplies power to all of the fuel injectors. It also supplies power to the EVAP canister Purge Valve, MASS air flow sensor, EGR Vacuum Regulator, and the Intake Manifold Runner Control solenoid along with the engine coolant temp sensor.
I know this pretty much means that most anything can be the problem. Let me ask you this, is there any engine codes? That might help you narrow down the field.
Short of that, I would start disconnecting things to see what is causing the fuse to blow. Another option is to take the car to a mechanic and have him track down the problem. I know it cost moeny, but it may be cheaper than just replacing parts that are not at fault.
Good luck, and let us know what you find.
Aug 21, 2006 at 8:51 AM
