'98 Ford Escort ZX2
MATT1982
  • 1998 FORD ESCORT
I've got about 115,000 miles on the car, but dont' know the engine size. About a year ago it started to misfire at the higher RPM range. I've had the plugs, wires, and fuel filter changed. I've run a ton of fuel injector cleaners through it but it still misfires. When it first starts, it runs fine, then after a little while (5 or 10 minutes) it starts to miss at the higher RPMs, and slowly gets worse, untill it starts to die out when idling. It seems to miss more often when accelerating or letting off the fuel, but not as often when just driving steadily. It used to only miss when burning regular unleaded fuel, but has started to do it when burning the higher octane fuel also. When it does it on the interstate, I can usually hit the clutch and turn off the car for 10 or 15 seconds then pop the clutch and it "resets" the problem. I'm a college student so I dont' have a ton of money to troubleshoot and the best the dealer can give me is that it's misfiring (as if I didn't already know that). Any ideas?
Thanks in advance,
Matt
Sunday, March 11th, 2007 AT 10:51 PM
CRAIGFL
  • 89 POSTS
Since this is an OBD II system, you should buy a reader and get the codes. They aren't always the full answer but they can be and they will help you start the troubleshooting process. Sometimes places like Auto Zone will read the codes for free-- don't forget to write them down!
Monday, March 12th, 2007 AT 12:47 PM
MATT1982
I have had them read before, but all it said was that multiple cylinders were misfiring, which I already knew. I'm not sure what the reader you're referring to is, but wouln't that have been what they used last time?
Monday, March 12th, 2007 AT 2:47 PM
CRAIGFL
  • 89 POSTS
It would be like these:
https://www.2carpros.com/trouble_codes/obd2/P0100
Looking at the codes helps diagnose the problem when you know the symptoms and all the P codes.
Monday, March 12th, 2007 AT 3:01 PM
