fuel injector removal - ZX2
FORD ESCORT
GREENBLOOD
Hello, 1st post. I have a 2001 Ford Escort ZX2 manuel shift with 131,317 miles on it. My wife ran it out of gas 2 weeks ago, and after getting gas the check engine light came on. It was losing power over the next 2 days and then quit. I pulled the fuel filter off and it was full of rusty dirty crap. I replaced the filter and it fired up after some cranking, so I changed the oil , air filter and plugs. It ran good for 2 days then would not start after turning it off. I checked the plugs and they are firing great but they are dry as a bone. The fuel pump shoots gas 14 inches or so out of the filter, and there is fuel getting to the rail. I think the injectors may be plugged up but I cant seem to get the clips off the rail to release them. I dont want to snap anything not knowing how this comes apart-- anyone know?
Jun 12, 2007 at 2:32 PM
GREENBLOOD
Never mind, did it myself. Fuel is coming out of all injectors. Has spark, has gas out of injectors, WTF? Maybe plugged converter?
Jun 14, 2007 at 9:46 AM
GREENBLOOD
OK finally got a handheld diagnostic to my car. Showing codes--P1383 cam timing over retarded bank 1--P0340 cam pos sensor circuit malfunction. What I need to know is how do you change the cam pos sensor?
Jun 19, 2007 at 6:51 AM
