94 Ford Escort w/1.9 liter - Alternator problems
GYMMFINN
I removed my alternator to gain access to replace my timing belt. The alternator had been removed and reinstalled sveveral times before and always worked properly. This time it is loading the engine down so far the it dies. When I disconnect the big, red output wire (with the engine running) I get a big spark as if it is drawing a huge amount OR somehow
shorted to ground. The other connections (3 wire multi-connector & 1 small spade connector) are in place and I am holding the large red output wire.
Touch it to the terminal and Big Spark and the engine slows way down. The battery is already charged so I don't think this is the DRAIN.
--mileage is "supposedly" 180,000--
Whu'dya think? :?
Nov 13, 2007 at 9:41 AM
SELTOR
  • 9 POSTS
There are three things I can think of. First, check to make sure everything is wired correctly to the battery. Second, check the ground cable. If you it isn't grounded properly, or in the wrong location, this will completely screw up the entire process. The last thing I can think of, go to your local auto parts store (Autozone, Advanced Auto), or wherever, and get your battery tested to make sure there is nothing wrong with that. Good luck!
Nov 20, 2007 at 1:03 PM
