2005 Ford Escort check engine light came on
71,622 MILES • 6 CYL • FWD • AUTOMATIC
LOCKSHMEE358
Yesterday I noticed that my check engine light is on. I dont know what could be causing it. I just put oil in it a few days ago so that should be fine Is there any minor things that could be causing this that I could check myself before taking it into a mechanic?
May 10, 2009 at 10:21 AM
BMRFIXIT
  • 19,053 POSTS
Need a OBDII reader to get the codes
check engine light come on when PCM detect a malfunction in the emission system and or that could effect it
codes will pin point the troubled area
check and make sure gas cap on and tight
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 10, 2009 at 11:09 PM
