2003 Ford Escort oil leak
49,000 MILES • 4 CYL • 2WD • MANUAL
BILLYBUCK
I have an intermittent oil leak coming fron underneath the car, on the drivers side. I checked the oil pan, it's tight, and the valve gasket cover seems tight also...any suggestions?
Jul 3, 2008 at 4:49 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Intermittent oil leak based on when the car is on or off?
Jul 3, 2008 at 5:44 PM
BILLYBUCK
the leak occurs whyen the engine is off.. a very small drip.
Jul 4, 2008 at 3:38 AM
AIRSOFTSOLDRECN9
  • 348 POSTS
Is your oil pressure guage on the drivers side? Check it. Make sure your valve cover isn't leaking either.
Jul 5, 2008 at 3:30 PM
