2003 Ford Escort Fuel delivery
81,000 MILES • 4 CYL • FWD • AUTOMATIC
BURNELLKENNETH
My car died on me while driving last week.It acted as if it were running out of gas,so i got gas and it still wouldnt start.So, then i checked the fuel pump fuse(20-amp)under the hood and it was blown,so i replaced it with a 30-amp because that was all i had and it started.I then drove 15-miles and it started to cut-out again and blew that fuse too.We replaced the fuse and it woulnt start again.We pulled out the back seat and noticed the wiring clip to the fuel pump was burnt.I tested the fuel relay and fuel pump and are both good.Its just not getting power to the fuel pump when i turn on the key.the shutoff switch is also been reset and still doesnt start.
Nov 8, 2008 at 7:20 PM
BMRFIXIT
  • 19,053 POSTS
recheck the wiring
check for power at the pump and also check for a good ground
Nov 8, 2008 at 10:10 PM
DAVE H
  • 13,383 POSTS
as BMRFIXIT has said this seems like a wiring fault .. use a multimter to test you are getting power to the plug .. if you are, then the plug is probably not connecting correctly because it is burnt .. replace the plug with new .. if you are not getting power then you will have to trace the wire back for a breakage ??
Nov 8, 2008 at 10:26 PM
