2003 Ford Escort ENGINE DOES NOT CRANK ENGAGE TO START
2003 FORD ESCORT
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
IBELLOSO
MY CAR STOPPED , BATTERY WAS CHANGED RAN FOR A DAY THEN STOPPED. THE ENGING CRANKS BUT DOES NOT ENGAGE LIKE IT HAS NO GAS. ALL FUSES ARE OKEY, GAS PUMP COILER CHANGED, DIAGNOSTIC COMPUTER DOES NOT SHOW ANY PROBLEM ANY SUGGESTIONS
Aug 24, 2008 at 1:49 PM
Do below and comeback with your results
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Aug 24, 2008 at 2:31 PM
