2002 Ford Escort valves?
TINACRAWFORD3
Engine Performance problem
2002 Ford Escort 4 cyl Automatic 157000 miles
i have a 2.0 L split port engine do the valves bend when the timing belt breaks..
and how would i know if that is what the problem is...its between this or the fuel pump...it wont turn over.
Mar 15, 2009 at 2:33 AM
MERLIN2021
  • 17,250 POSTS
Remove the serp belt, then the three nuts holding the timing cover on, then inspect the belt, with 157,000 it's time for a new one anyway...let me know if you need the proceedures. I dont think you damaged anything.
Mar 15, 2009 at 2:41 AM
