2002 Ford Escort ses
117,000 MILES • 4 CYL • 2WD • AUTOMATIC
PATTIANNG
my sevice engine light just came on why? we just replaced sparkplugs plug wires pcv valve air filter oil change the light is service engine soon i also put sea foam in there also thank-you
Mar 11, 2008 at 1:35 PM
BMRFIXIT
  • 19,053 POSTS
For you to pin point the reason you need to have it scanned
for codes with out the codes you could spend weeks replacing parts
check fuel cap
you have hundreds and thousands of possibility with out the codes
you are fishing in a big ocean
Mar 11, 2008 at 1:46 PM
