2002 Ford Escort rough idle in gear under load
2002 FORD ESCORT
SHAWNSCLASSICS
Engine Performance problem
2002 Ford Escort 4 cyl Front Wheel Drive Automatic
car runs great in park or when heater or air is off but when in gear and heater is on the car starts idling rough if i barely give it gas it runs perfect again the car only has 70000 miles on it
Apr 15, 2008 at 4:56 AM
MJKTIG2
I bought an 02 Escort last September. It was extremely clean and had 105,000 miles. The only problem I had was exactly what you described. I took it back to the dealer and at his expense, he replaced the motor mounts. It helped alot, but it did not completely illiminate the vibration. I discovered that this problem was the result of a manufacturing issue with 02 Escorts and Tracers. There is a pdf document that you can read and/or give to your mechanic.
I hope this helps.
mjktig2
Apr 24, 2008 at 12:42 PM
