2002 Ford Escort po125
99,000 MILES • 4 CYL • 4WD • AUTOMATIC
ACERS30
Ive changed both ect`s ,thermostst and I still get a po125 code. after about a day. do u have any ideas?
Jul 26, 2009 at 12:07 PM
LAZYGAZER
  • 68 POSTS
Code P0125 is Insufficient coolant temperature for closed loop fuel control.
This could be that the coolant is not getting to specs for normal operation,your coolant temp. sensor could be faulty sending wrong info to the EEC. Also check for coolant flow.
Aug 2, 2009 at 1:11 PM
ACERS30
thanks for the info. I`ll try to change both sensors..
Aug 6, 2009 at 1:29 PM
