2002 Ford Escort oil pressure
CHEVYRYDER187
Engine Performance problem
2002 Ford Escort 4 cyl Front Wheel Drive Automatic
How do you do an oil pressure test on a 2002 ford escort, and what are the specs for the test
May 26, 2010 at 10:20 AM
  • 31,937 POSTS
Hi there,
you will need a mechanical oil pressure gauge that will screw into the oil pressure switch port, you will be looking for 35-63 PSI Hot @ 2000RPM.
Mark (mhpautos)
May 26, 2010 at 10:43 AM
