2002 Ford Escort Heater blows cold air
2002 FORD ESCORT
180,600 MILES • 4 CYL • FWD • AUTOMATIC
NOMADRIDER
I just bought this Escort and the heater blows cold air. Would I be wrong in thinking the thermostat is stuck open and need replacing? The tempature on the guage builds up to normal operating tempature.
Mar 19, 2008 at 11:41 PM
2CARPRO JACK
  • 11,533 POSTS
Might be plugged up, or the heater control valve (if equipped) isnt working not letting hot water in. Do the heater hoses get hot? If engine temp is normal, probably not the t-stat
Mar 20, 2008 at 7:52 AM
NOMADRIDER
Thanks for your help......I found the problem.....Where you switch from cold to hot, the mechinism had come off the shaft that switches it.....
Mar 20, 2008 at 6:22 PM
