2002 Ford Escort Fuel pump? code po190
78,000 MILES • 4 CYL • 2WD • MANUAL
MONKEYSHINE39
My car started hesitaiting the other day and yesterday it took 30 minutes to get it started. I was sitting on a hill front of car facing downhill it would not start so I pushed it to level ground. My friend may be coincedence smacked the fuel tank with his hand and a couple minutes later it reluctantly started. It now intermetenly stalls when coning to a stop and some times when pulling out lacks a lot of power and sputters. After running it for a while it seems normally. It also shudders when accellerating(intermitanlly). It threw a code po190 fuel rail pressure sensor malfunction.
Sep 4, 2008 at 5:18 AM
BMRFIXIT
  • 19,053 POSTS
Possible causes for this fault are:
 Open Circuit In Harness
 Open Circuit In Sensor
 Open Circuit In PCM
Sep 4, 2008 at 11:18 PM
