2002 Ford Escort Fuel Problem?
2002 FORD ESCORT
02ESCORT
Engine Mechanical problem
2002 Ford Escort 4 cyl Automatic 84k miles
A few weeks ago driving on the highway my car suddenly acted as if it were not getting gas. It recovered quickly, but this problem has started to happen more often. It will slow to idle, and pressing on the gas usually has no effect. Sometimes it will cause the car to lurch forward a number of times. I have to pull over and wait a bit for it to catch again. Now I am having trouble starting it in the morning. I have replaced the fuel filter and pcv valve. What is next, the fuel pump? Where is this located?
May 10, 2008 at 2:02 PM
BMRFIXIT
  • 19,053 POSTS
fuel pump is located in the gas tank
I would check for fuel pressure before replacing the fuel pump
do you have any check engine light on
check for codes
May 10, 2008 at 2:20 PM
02ESCORT
No check engine light. Can I access the fuel pump easily? As in, is there an access panel under the back seat or in the trunk?
May 10, 2008 at 2:24 PM
BMRFIXIT
  • 19,053 POSTS
Disconnect negative battery cable
release fuel pressure
_____________________
remove rear seat cushion
disconnect the wiring harness connectors
remove 4 screws on access cover
if any dirt around fuel pump module you should clean it
disconnect fuel line
remove retainer ring
May 10, 2008 at 2:36 PM
02ESCORT
Thanks...I'll look at this tomorrow in the daylight.
May 10, 2008 at 2:42 PM
BMRFIXIT
  • 19,053 POSTS
Im not for changing parts check first the fuel pressure (35-65 psi)
May 11, 2008 at 12:45 AM
