2002 Ford Escort Fan isn't working
113,000 MILES • 4 CYL • 2WD • AUTOMATIC
RDEROZIERE
When I attempt to turn on my defroster to remove the frost from the windows the fan switch is no longer working. There is heat coming out, but no blower on any of the four settings.
I checked the fuse and it looks ok.
Is this is an electrical or fan issue?
What is the solution, the parts to fix it, and if I can't get to it will a dealer repair the problem if I provide the part?
Robert
Dec 19, 2007 at 9:59 PM
KNOBBY
  • 37 POSTS
first you have to see if you have voltage and ground giong to the blower motor it could be the switch or the motor or the resister or wiring go to any shop they will charge 1/2 hour to find what you need you will save money dont guess
Dec 19, 2007 at 10:30 PM
