2002 Ford Escort fan inoperable except on #4-hIGH SPEED
2002 FORD ESCORT
33,000 MILES • 4 CYL • FWD • AUTOMATIC
GRACESFORD2002
fan will only operate on highest setting-4.
A/C light on a/c switch lights,but no air conditining or fan. When I turn the fan to Max, the A/c light goeas out but then the fan begins to operate.
The fan does not work for other selections at lower speeds, it only kicks on at full (setting 4)
Thank you
Aug 7, 2009 at 7:09 AM
2CARPRO JACK
  • 11,533 POSTS
Locate the fan speed resistor next to the blower motor.Use atest light or meter to see if any power is going into it at different fan speeds.If yes, the fan speed resistor is bad
Aug 10, 2009 at 6:55 AM
