2002 Ford Escort Codes P1120 and P0122
JKZAP
2002 Ford Escort Two Wheel Drive Automatic 101574 miles
Hi my check engine light turned on the other day so i went and got an oil change along and fluid check and fill done. My car is still having trouble with its throttle though. It feels almost like my transmission is going out. It drives fine when i keep a constant speed but when i am at a stop and accelerate it is starts of real slow and then gets real jerky. Anyways i had the guys at the shop do a quick computer check on my car and the codes P1120 and P0122 showed up in a pattern, one after another and each showed up 4 times. Please help me :D
Mar 26, 2009 at 2:24 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:40b0359a58="jkzap"]2002 Ford Escort Two Wheel Drive Automatic 101574 miles
Hi my check engine light turned on the other day so i went and got an oil change along and fluid check and fill done. My car is still having trouble with its throttle though. It feels almost like my transmission is going out. It drives fine when i keep a constant speed but when i am at a stop and accelerate it is starts of real slow and then gets real jerky. Anyways i had the guys at the shop do a quick computer check on my car and the codes P1120 and P0122 showed up in a pattern, one after another and each showed up 4 times. Please help me :D[/quote:40b0359a58]
Here are the Code Defs.....
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P1120 TPS Out Of Range Low
Recommend replacing TPS (Throttle Position Sensor)
Mar 26, 2009 at 2:31 PM
