2002 Ford Escort car dosent want to go over 20mph
RONNIE211
  • 6 POSTS
2002 Ford Escort 4 cyl
my car drives fine for about 20 minutes then dosent want to go over 20mph and makes a thumping sound in the engine and seems like it sucks up alot of fuel and when i take my foot of the accelorator it just comes to a quick stop whats the problem
Ronnie.
Oct 31, 2010 at 3:20 PM
  • 75,988 POSTS
Could be the catalytic converter clogged-up -check the exhaust system for restriction by doing a backpressure test
Nov 1, 2010 at 3:28 AM
RONNIE211
  • 6 POSTS
Thanks ill try that
Nov 1, 2010 at 4:58 AM
RONNIE211
  • 6 POSTS
if it is a clogged catalytic converter would there be smoke comming from the exhaust because there isnt it mostly smokes from the engine?
Nov 1, 2010 at 6:17 AM
  • 75,988 POSTS
Check the exhaust system for restriction disconnect the exhaust pipe from the exhaust manifold and see what happens and then comeback with some results
Nov 1, 2010 at 6:22 AM
RONNIE211
  • 6 POSTS
i went to a general Micanic and got a new catalitic converter he said i needed one and i drove it home and it seemed like it was driving worst then ever do you think i need to talk it to a muffler shop or whats my next step it was smoking like crazy a sweet smell and stinking up the naborhood still didnt want to go over 20mph and making a thumping in the engine. thanks Ronnie
Nov 3, 2010 at 11:31 AM
  • 75,988 POSTS
Check all the cylinders if it has water/coolant -you sounded as coolant is burning in the combustion chamber-sweet smell
Nov 3, 2010 at 12:39 PM
RONNIE211
  • 6 POSTS
the smell i think is trasmission fluid from reving the engine to hard to get up to speed
Nov 3, 2010 at 7:19 PM
RONNIE211
  • 6 POSTS
your probably right it probably is coolant but still what is going on why isnt it driving well what can do now ?
Nov 3, 2010 at 7:48 PM
  • 75,988 POSTS
If its leaking its causing the transmission to slip due to low fluid-get it fix
Nov 3, 2010 at 8:37 PM
