2002 Ford Escort cam sensor
126,234 MILES • 4 CYL • 2WD • AUTOMATIC
VERNSGIRL
problem code indicates that the cam sensor is the problem, how do you replace this? any other parts to trouble shoot, wont accelerate beyond 50, difficulty with idling and rough shifting after 1st, thanks so much!
Jul 12, 2008 at 6:16 PM
SERVICE WRITER
  • 9,123 POSTS
How old is the timing belt, may have jumped a tooth. Check the top of the shaft under the cam sensor for abnormal wear. IF so replace shaft and sensor.
https://images.2carpros.com/forum/automotive_pictures/30961_ckp_1.jpg
Jul 13, 2008 at 12:35 AM
