2001 Ford Escort Vehicl speed sensory malfuntion PO500
SINJINNAGA
Computer problem
2001 Ford Escort 4 cyl Automatic 100000 miles
How do I fix it when code PO500 appears on the OBD2?
Sep 28, 2009 at 1:20 AM
DAVE H
  • 13,383 POSTS
replace the VSS (vehicle speed sensor)
Sep 30, 2009 at 2:36 PM
RICK 08
  • 54 POSTS
Hi: This sounds like you have receivied advise on replacing the speed sensor (VSS). For what it is worth I have done this, while the concept of removeing it seems easy. It was for me a challange to remove it. (Stuck)
It is interesting to note while while in my case sensor resistance values fell within spec. The sensor was still bad (PO 500) Should you elect to do this work yourself and have problems, please repost your issues. I will further articulate!
Oct 2, 2009 at 4:43 PM
