2001 Ford Escort slipping
2001 FORD ESCORT
120,199 MILES • 4 CYL • FWD • AUTOMATIC
CHRIS6911
  • 22 POSTS
I have a 2001 Ford Escort, when i drive my car about a mile or so it would drive fine until i have a stop. As i step on the gas pedal in the start of the go my car will jurk into the next gear. It doesn't do this all the time just when it is a hot day or i go on the freway and get off then go again. What if anyting can i do to fix this problem?
Aug 25, 2010 at 10:46 AM
  • 110,240 POSTS
Is the trans fluid clean and full?
Sep 2, 2010 at 5:07 AM
CHRIS6911
  • 22 POSTS
yes my transmission was flushed. It would start to jerk after i run the air conditioner to.
Sep 2, 2010 at 4:32 PM
  • 110,240 POSTS
Are you sure the trans is the issue and not an engine miss?
Sep 3, 2010 at 2:59 AM
