2001 Ford Escort Service Engine Soon light is on
181,000 MILES • 4 CYL • FWD • AUTOMATIC
DEBBIE MINNIS
My question is about my 2001 Ford Escort. After I put new spark plugs and wires on the Service Engine Soon light came on about a week later. It drove fine so I have ignored it. I needed brakes put on and decided to have them also check about the light. They said I needed a PCV valve and hose. I also got them to replace the fuel filter and clean the system. After I picked up the car, the Service Engine Soon light did not come on, however, after starting it 2 more times while running errands, the light came back on. Why would this happen? Can I reset it myself or does the dealership where I had the repairs done need to reset it? I would appreciate your help with this question. Thanks.
Debbie M.
Jun 24, 2008 at 10:25 AM
BMRFIXIT
  • 19,053 POSTS
You need to get the codes 1st and before you reset the light
auto zone and most local repair shop will help you getting the codes for free
as for resetting it you can do so by disconnecting the battery
you may post the code more help
Jun 24, 2008 at 1:17 PM
