2001 Ford Escort Oxygen Sensor Replacement
93,000 MILES • 4 CYL • FWD • AUTOMATIC
DENNIS
I am trying to replace the oxygen sensor (the one between the engine and fan) but I have had difficulty.
I was wondering if there was an easy way or if it is just tricky. I don't see how you would get a wrench in to loosen the part that goes in the engine.
Any help will be appreciated
Thanks,
Dennis
Jun 19, 2008 at 7:14 AM
DOCFIXIT
  • 18,828 POSTS
Try the biggest box end wrench you can find.Slid it down over the O2 and pull like thereis no tomorrow. Alittle penetrating could help also run engine a little the heat will help.
Good luck
Jun 19, 2008 at 7:29 AM
