2001 Ford Escort overheating due to cooling fan not working
54,000 MILES • 4 CYL • 2WD • AUTOMATIC
GARRYDON
my escort SE over heats because the cooling fan fails to run. I have checked the relays and fuses under the hood and under the dask, they are Okay. I put a new coolant temperture sensor on. I have hot-wired the cooling fan to 12-volts, it runs. The cooling fan runs just fine when I turn on the air-conditioning, but turns off when I change back normal running without the heater turned on. I am beginning think it is a bad computer?
Apr 5, 2010 at 7:22 AM
  • 75,988 POSTS
Its the computer that senses the input signal from the engine coolant temperature sensor or the engine temperature gauge sender to energize the fan relay
Apr 5, 2010 at 8:11 AM
