2001 Ford Escort overheating
2001 FORD ESCORT
AL531
Air Conditioning problem
2001 Ford Escort 4 cyl Two Wheel Drive Automatic
When the A/C is on the temptuer goes up high causing the vehicle to get hot. however when the A/C is off there is no overheating, what con cause this problem?
i have changed the thermostat and the fan is working properly.
Nov 9, 2010 at 2:43 AM
  • 110,236 POSTS
I have a couple questions. Does it run hot when you are at highway speeds or only in town driving? Next, have you checked if the cooling fans are both working when the AC is on and the temp starts getting high? Finally, have you ever had the cooling system flushed and a new thermostat?
Nov 10, 2010 at 7:36 AM
