2001 Ford Escort no spark
MR.CARMAN27
Engine Mechanical problem
2001 Ford Escort 4 cyl Front Wheel Drive Automatic
my car is not gettin spark tryed changin the comp and I put a new coil pack on it ....its gettin power to the coil pack but is not sendin it through the coil pack to the wires can u help me
Nov 19, 2009 at 2:27 AM
BMRFIXIT
  • 19,053 POSTS
check timing belt
check fuses ,relays
with key on do you have check engine light on ?
(you should )
also check for codes and pending codes
Nov 19, 2009 at 8:34 AM
