About a week ago, I noticed that my instrument panel lights were not working, Prior to this incident my car would not start I located the problem and it was a bad negative terminal on the battery, I had a temporary fix in which I crimped vice grips to lead, so I could drive my car. The proplem with the illumination was a blown fuse. I replaced the fuse and not five minutes later the fuse blew again. I replaved the bad terminal with a new one, and attempted to replace the fuse again, with the same results. Do you know what this problem could be caused by?
Sep 26, 2009 at 7:26 AM
